US roaming bundle data doesn’t work
yanxi
I bought the US roaming minutes, texts, data bundle on Dec 7. I’m in Miami. The data doesn’t work. Could the agent help? Thank you so much!
7 REPLIES 7
hycm53
@yanxi wrote:
So you mean it works in Buffalo, but not some part in Florida? Thank you very much.
Since USA shut down 3G service this year, voice talk in some place won't work. But data add on should be fine.
yanxi
@yanxi   I am pretty sure you were using the roaming when you were in Buffalo.  US network signal is much much stronger than Canadian
Florida connection is a mix from the review.  Someone confirmed it wasn't working well in Sarasota area. But other reported central and west coast Florida was good with data, voice was unreliable
Try again in different area and hope it works.
Worst case, when you are back, open ticket with PM and they will likely compensate it based on your experience.  And for now, maybe head to a Walmart to get local data sim
yanxi
Data was on. Roaming was not. I just opened it, but it still doesn’t work. I made phone calls in Buffalo. It worked. Not sure if it works, or because it’s close to Canada. I just tried now, and the phone call and text didn’t work either.
yanxi
It’s already T mobile. Thank you very much.
Quigley
@yanxi
Try choosing T-Mobile as your network of choice from inside your phone settings.
See if that makes a difference for you.
dust2dust
Everything else works? Is roaming data on? Is data on?
