10-20-2019 10:24 AM - edited 01-05-2022 07:39 AM
Hi, I purchased a US roaming unlimited talk add-on for 10 days for $8. I tried to call a US phone number which is valid (my aunt in Florida). I got a voice message which said "sorry you vant make this call because you don't have a purchased US add-on." However on my self serve account the add-on is showing up on my payment history as paid $8. It is also showing up on my plan as an add-on. Please help. Thanks
10-20-2019 10:48 AM
Thanks for the info
10-20-2019 10:48 AM - edited 10-20-2019 11:03 AM
You should consider textNow if you have data or access to WiFi. They will give you free Canadian number and unlimited talk and text to both USA and Canada.
I use it with my 15 public mobile plan to turn it into practically unlimited North America for $13.
Edit it uses 30-40 megs of data (with background data restricted) monthly in my case, I'm not heavy user.
10-20-2019 10:41 AM
@ShannonWooUnfortunately there is no unlimited add on options for calls to the US at Public Mobile. The best you can do is $15 for 400 international minutes https://www.publicmobile.ca/en/on/plans This doesn't expire until you use it all up.
10-20-2019 10:39 AM
You need to buy the long distance add on, not US roaming.
Here are the two options:
400 International Long Distance minutes $15
Included countries: Canada, China, France, Germany, Greece, Hong Kong, India, Italy, South Korea, Malaysia, Mexico, Poland, Portugal, Puerto Rico, Singapore, Spain, Thailand, United Kingdom, United States, and Venezuela.
200 U.S. & Canada Long Distance minutes $8
10-20-2019 10:36 AM
Ah...I see. Thanks. Do you know which addon I'd need for unlimited calls to the US then?
10-20-2019 10:34 AM
I'm in Canada trying to make a phone call to the US. I purchased talk only so data roaming doesn't apply. Thanks
10-20-2019 10:29 AM
Are you prently in the USA? Trying to call a US number?
A few things to try:
Enable roaming
Reboot phone
Manually choose carrier either AT&T or T-mobile. Try one, then ther other
Toggle airplane mode on, then off
The following numbers in the USA are not able to be called:
Calls made to numbers starting with the following six digit combinations are not included in U.S. Roaming talk Add-Ons or U.S. calling from Canada and will not be completed when dialed: 712-432, 605-562, 641-552, 605-475, 605-477, 712-775, 559-726, 530-881.
10-20-2019 10:29 AM
I have rebooted. Still not working. I will add a ticket thanks
10-20-2019 10:28 AM
@ShannonWoo are you in Canada or in the US? That roaming add on is to use when you're in the states
10-20-2019 10:27 AM
Make sure you enable roaming. Try reboot ing your phone. If you still have problems then submit a ticket by clicking on the question mark on the bottom right.
https://www.publicmobile.ca/en/on/get-help/articles/us-roaming
