06-10-2019 08:08 AM - edited 01-05-2022 05:18 AM
06-10-2019 04:41 PM
@computergeek541 wrote:
@Ronak53 wrote:I have purchased US add on but still I am not able make any calls to Canada fron USA. Any solution? I have full network.
I'm wondering if a similarly named U.S. long distance add-on may have accidently been purchased instead of a roaming add-on.
This is true, there is an add-on called "200 min US and Canada Long Distance" which may be confusing, since it will only work in Canada. Is it possible that you've purchased this add-on by mistake?
All the add-ons that will work in the US have "US Roaming" in the title and specify 10 days.
06-10-2019 04:31 PM
06-10-2019 10:11 AM - edited 06-10-2019 10:11 AM
@Ronak53another thing we don't know.. when did you purchase the add on (hopefully within the last 10 days)?
06-10-2019 09:58 AM
Login your self-serve account.
Do you see the US roaming add-on on your overview page?
If yes, enable roaming on your phone. Restart your phone. You will be connected to AT&T or T-Mobile.
06-10-2019 09:25 AM
06-10-2019 09:00 AM
You can check your self service account to see whether your US roaming add on is in your overview page.
Here is a thread on how to purchase add on:
Also, make sure that your roaming is turned on in your phone.
06-10-2019 08:15 AM
This is a two-step process. Have you 're-purchased' after adding the funds?
If your money is still sitting as available balance, you need to re-add the addon.
There will be no extra charge.
