03-08-2022
04:16 PM
03-08-2022
04:19 PM
computergeek541
Hi, I just purchased 1000 minutes of US long-distance calling. I'm in Texas. I can't seem to make any calls. Previously, I had purchased the bundle of data, texting and calling (for 10 days) and that worked fine. My wife is having the exact same problem.
Thanks,
Paul
03-08-2022 11:43 PM - edited 03-08-2022 11:44 PM
Contact customer support and leave a detailed message explaining your honest mistake and ask them to remove the add on and credit your account the $15. If you want them to add one of the US Roaming add ons for you at the same time you can do this as well but make sure you have enough funds in your account so you may need to add an extra $5 if you want the $20 US Roaming bundle.
You will have better voice call service by manually selecting T-Mobile rather than at&t as they have already begun decommissioning their 3G network that pm uses for voice calls so voice services with them can be hit and miss. T-Mobile does not begin this until July 1st 2022. Not long after that pm will lose all voice services while in the US. The workaround is to download a voip provider like textnow or fongo to use on the 4G LTE network. Fongo uses about 0.5mb/min or 100mb=200min of mobile data or they will work on wifi as well.
03-08-2022 07:39 PM
unnecessary repetition
03-08-2022 05:52 PM
HI @psq56 these are the proper US add-on you should have purchased.
You can ask PM CS Agent to exchange that for you if the one you one is within $15. If you want to go with the $20 one , it is better for you to load $5 extra onto the account and then PM CS Agent can process immediately
US Roaming - Unlimited Text (10-day) - $8.00
US Roaming - Unlimited Talk (10-day) - $8.00
US Roaming - Talk Text (10-day) - $15.00
US Roaming - Talk Text 250 Data (10-day) - $20.00
US Roaming - 1 GB Data (10-day) - $20.00
US Roaming - 250 MB Data (10-day) - $10.00
US Roaming - 500 MB Data (10-day) - $15.00
03-08-2022 05:44 PM - edited 03-08-2022 05:46 PM
Contact customer support for assistance.
They will likely permit you to use the funds to purchase the US long distance add on to instead purchase the correct US roaming add on.
Here how to reach them:
https://www.publicmobile.ca/en/ns/get-help/articles/contact-an-agent
03-08-2022 04:18 PM
@psq56 wrote:Hi, I just purchased 1000 minutes of US long-distance calling. I'm in Texas. I can't seem to make any calls. Previously, I had purchased the bundle of data, texting and calling (for 10 days) and that worked fine. My wife is having the exact same problem.
Sorry, but long distance minutes are of no use to you. The add-on that you purcahsed is for used while you're in Canada (to call the U.S.). You'll need to purchase a roaming add-on.
