10-07-2025 05:49 PM
I used points to redeem 3gb of data within canada, as I ran out the other day.
The data is not working, and it seems that it gave me usa roaming data.
Is there any way to swap the data it gave me? as I am unable to use it.
10-20-2025 11:08 PM
10-07-2025 06:19 PM
@KyleO1 Yes support is usually able to help reverse charge and give you the proper add on just engage them .
you can use the orange chat bubble bottom right of screen or send a private message To CS_Agent
