Reward Data add-on is not worki ng
Antoine2
Hello,
I have activated one of my rewards yesterday and the addon data I got (1GB) is still not working.
@Antoine2 wrote:
Is this a forum or did i open a ticket? I meant that I used my reward points to get 1gb of data and its still not working
@Antoine2
This is the forum.  The ticket system is not working presently.  If you tried the previous suggestions, then you will need to private message CS_Agent:
@Antoine2
Try rebooting your phone by powering off then back on to see if that helps.
Antoine2
Meow
I do not think you have to activate anything to use gift data. As you use all your allocated data reward/gift data should start.
porcupine
Click on the envelope in the bottom right corner and follow the prompts for help
