08-17-2024
04:35 PM
08-17-2024
05:33 PM
computergeek541
08-17-2024 04:41 PM
yes it will work. Many do that
But make sure you know that new US iPhone has only eSIM (but no worries, PM has esim support too)
08-17-2024 04:40 PM - edited 08-17-2024 04:41 PM
Of course. This iPhone should NOT be locked. As long as it's unlocked, you should have no problem. I would suggest however that once you get it, you do a factory reset to make sure it's not locked to a provider. I've heard of some providers locking their phones again until the phone is paid off. Then after the factory reset and the phone is still unlocked, you're golden. This is just a way to protect yourself.
