3 hours ago
Hello community.
I'm currently on the $34 a month plan (attached below): wondering if the third bullet means I can make calls while in the US or if it's only calls Canada -> the US.
Thanks!
2 hours ago
3 hours ago
Yes, this is a US roaming plan. So you can make calls in the United states to either Canadian or other USA numbers.
3 hours ago
you can make calls from US to US and from US to Canada as well
