05-20-2022 10:50 PM
I purchased the 10 day unlimited talk and text and 250 data plan for travel in the US. I have used a lot more data than planned, can I top that up, or do I have to wait until the 10 days expires?
05-21-2022 03:13 AM
It would get quite pricey, you may want to look at a local prepaid data option. Also even after 10 days If you wanted the exact same add on you'd have to wait 24hours after If you were doing it manually, unless you get a CSA to manually activate it right away
05-20-2022 11:30 PM - edited 05-20-2022 11:30 PM
Now you know by the two previous replies that you can. Keep contributing the more you are here the more you will learn. When you don't know the answer try putting it in the search bar and hit go. You will be given a bunch of threads to read with or without solutions. Get a few with the same solution and you likely have the answer. (Contacting customer support not withstanding?!!) Then return to the thread and post the info you just found. The search bar has been my best friend since joining the community.
o contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-20-2022 10:55 PM
It would be great to be able to add more, but I believe you have to wait till the 10 days expire. Hopefully someone with more experience can help you with this one. Good luck! 😊
05-20-2022 10:55 PM
You are able to buy an additional data alone add on before the 10 days are up with your original roaming package. You just can't purchase the exact same roaming package before the 10 days are up.
Here is some additional information:
https://www.publicmobile.ca/en/on/get-help/articles/us-roaming
05-20-2022 10:54 PM
You can go ahead and buy any of the other buckets. US Roaming...not Canada. Come back if you need to extend talk. Don't buy another of those until the 10 days (240 hours) have passed.
