US data package didn’t work
Christyk
I purchased a US data roaming add on. I’ve done this in the past and it has worked, no problem. This last time, however, the data never worked once in the US. When I checked later it said I had used up the days (purchased a 10 day package) but the data never worked to begin with.
I would like a refund of the $10 I spent on this but was never able to use it.
HI @Christyk
did you submit a ticket and ask for refund?  If not, submit one now:
Christyk
Yes. Data roaming was enabled at the time. No not Alaska. I live in BC and went across the border into Washington
Christyk
Data roaming was enabled at the time of (attempted) usage.
Flyingfinn1982
Make sure data roaming is on.
DennyCrane
The packages are now 15 days. Did you buy the 250MB  add-on? Was data roaming enabled on your device itself? You weren't in Alaska, were you?
Please submit a ticket using the chatbot to dicuss this with a customer support agent:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
