06-18-2023 06:34 PM
06-22-2023 01:29 PM
Thanks BKSN. i only created the eversafe account with the one account I have for my wife.
I created another account for my mother in law 2 years ago, and I gave her the information, but she can't find it.
Now I can't get in.
06-18-2023 08:01 PM - edited 06-18-2023 08:01 PM
Did you create a Eversafe ID yet with both accounts?
If you did then you should have gotten an email from PM welcoming you. Conduct a search on your inbox for possible email address for the second account then click on Forgot Email or Password.
06-18-2023 07:04 PM
Thanks softech I read below your message
06-18-2023 07:00 PM
@Dee62 yup, use the direct link above.
06-18-2023 07:00 PM
Sorry softech
06-18-2023 06:59 PM
Thanks softens, how do I contact support.
06-18-2023 06:36 PM - edited 06-18-2023 06:36 PM
@Dee62 did you try using the Forgot Email and Forgot Password link there on the Login page? they will send code to your phone and the reset process starts there
If that does not help, please message support directly:
