New phone number
DanielRoyer
The system won't let me change my phone number
HI @DanielRoyer  you are not trying to port in number, right?
If you are porting in number, you don't use Change number, you go to Profile page and click Transfer number
if you really want to pick a new number to change , try using Incognito/Private/Secret mode
@DanielRoyer @Are you trying like this
Change # on profile tabs
@DanielRoyer  I guess you went to the right place?  What was the error?  maybe a screenshot?
Try using Incognito mode first.  If still fails, try using a computer or different device
https://myaccount.publicmobile.ca/en/account/profile/update/phone-numberhttps://myaccount.publicmobile.ca/en/account/profile/update/phone-number
