12-28-2023 08:19 PM
I put a US talk and text add on yesterday and now today that I amin the States only the text works, NO TALK. Now I try to get an agent and there is always a problem submitting the ticket! Thanks alot publicmobile
12-28-2023 09:07 PM
@MURRAYDEEP wrote:i cant choose 2G....but i shut off data roaming, and seems to work outgoing.....and INCOMING !!!!! Thank you everyone for helping us with this problem !!!!! we are back in business...and everything working as it should.....thanks again....from an old Canadian man......lol...
HI @MURRAYDEEP glad it works. Happy holiday, enjoy the trip
12-28-2023 09:07 PM
@MURRAYDEEP .yay we happy to hear it enjoy your trip and happy new year 🥳
12-28-2023 09:06 PM
12-28-2023 09:03 PM
@Cricket2 wrote:Hi phone only gives the option of LTE or 3G. . That’s it! That’s all!
the 2G is there and just hidden. Change back to Automatic with network mode, but select T-Mobile as the carrier and test again.
12-28-2023 09:02 PM
@MURRAYDEEP I’m sorry your experiencing these issues please use this direct link to to support to submit ticket
send a private message To CS_Agents
12-28-2023 09:01 PM
12-28-2023 08:59 PM
yes
12-28-2023 08:58 PM - edited 12-28-2023 08:59 PM
@MURRAYDEEP wrote:im old, and fustrated...we are on our way to Florida, and cannot get my phone to work...my partners mother is not well at the long term place, and we have to be able to receive calls from the long term care she is in....we tried to submit a "ticket" multi times,, and technical error comes up.???
did you try connecting to T-Mobile and change network mode to 2G?
For ticket with agent, please open by direct message:
12-28-2023 08:55 PM
12-28-2023 08:54 PM
@MURRAYDEEP Have you rebooted the phone since purchasing the U.S. roaming add on by any chance
12-28-2023 08:54 PM
Hey @MURRAYDEEP
Follow these steps.
How to change Network Operators on iPhone
Press Settings
Press Network Selection
Press the indicator next to Automatic and turn it off.
Then pick T-Mobile for US usage.
Then swipe up and close. It’s best to reboot if possible.
You should be good to go.
Created by Chalupa Batman
12-28-2023 08:53 PM - edited 12-28-2023 08:53 PM
are you connected to T-Mobile or AT&T?
With your issue on voice, make sure VoLTE is enabled on the device setting.
And if it does not work, try to change the Network to T-Mobile ONLY, and change Preferred Network Type or Network Mode to 2G and see if the calls go through.
Also, you can download VoIP app TextNow as a workaround to make calls and text if you have Wifi or if your roaming has data component and data is working
12-28-2023 08:52 PM
my phone is an i phone 7.....text works, but no phone response incoming or outgoing...
12-28-2023 08:46 PM
Hey @MURRAYDEEP
Are you using an Android or iPhone?
12-28-2023 08:21 PM
@MURRAYDEEP Make sure you got he correct US. Roaming add on . And put phone to 4G/LTE and connect to T mobile or AT&T also ensure you have data roaming tuned on in phone settings . If you have any issues with voice out phone to 2G and connect to T mobile
