10-29-2022 10:36 AM
I've tried several times to purchase a US add on. I have lots of funds available and the system gives me a receipt. I check my payments and it doesn't show up, no funds are debited and no US add on started
10-29-2022 01:47 PM
I think one or more of your previous add-ons were still in their 10 days when you tried to purchase again. Or the weird 24 hour re-buy delay had not yet passed. This might be a new thing in the new system - it looks like you bought it but it only puts the money in the account.
10-29-2022 01:35 PM
They charged my credit card and it shows that I have those funds in my account but the add on purchase isn't going thru (i.e. no funds debited)
10-29-2022 01:22 PM
Hi @dveldhuis99 of you see sure PM didn't charged your credit card open ticket with PM amd see if they can help you to buy
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
or you can simply can local data prepaid in US, and use VoIP app TextNow to make calls instead.
10-29-2022 01:22 PM
Are you seeing these payments coming out of your credit card? Or did you already have a balance on hand?
Keep clicking those little spinner refresh icons lower down or stay in private mode (or both). Are you using a mobile browser? Maybe try desktop mode with it.
But the critical part is, is money being spent.
10-29-2022 01:20 PM
I purchased the first one 12 days ago while in Utah. It worked for 10 days while in Arizona but now won't allow my purchase of a 2nd 10 day US add on.
10-29-2022 01:19 PM
Still doesn't show any purchase (i tried buying US add on 3 times now, each time getting a receipt)
10-29-2022 01:17 PM
No luck again
10-29-2022 01:11 PM
No luck again. Doesn't show the purchase that PM gave me a receipt for.
10-29-2022 01:06 PM
No luck
10-29-2022 10:42 AM
Be very confident UP add-on will work at all before purchasing it. Don't be disappointed if it does not work when you get to US.
10-29-2022 10:39 AM
@dveldhuis99 try to login with Incognito mode to confirm if those transactions indeed went through. There is some cache issue on this My Account site
If there was not purchase, try buying again with your Incognito browser
10-29-2022 10:39 AM
Try rebooting the device, and refreshing the PM self-serve account screen.
You might also find that logging out, clearing cache and cookies, then opening an incognito tab and logging in again will allow you to 'view' the purchase and add-on.
10-29-2022 10:38 AM - edited 10-29-2022 10:39 AM
Try logging out and back into your account. Also try restarting your phone.
