US add on not working
Cricket2
Hello my US add on is not working .  I bought talk and text.  Can someone tell me how to configure my phone for it to work.  I have a Samsung galaxy s10.  Thanks
Cricket2
Thank you VERY much!  Phone works now
@Cricket2 wrote:
Everything you said has already been done but I can’t find where to go to make sure it’s on 4G.  Will keep looking thanks
@Cricket2 android or iphone?
Android:
1 Head into Settings and tap on Connections. Head into Settings and tap on Conections ; 2 Tap on Mobile networks. Tap on Mobile networks ; 3 Select Network Mode 4. Choose your preferred network mode
IPhone
1. Press Settings.; 2 . Press Mobile Service 3. Press Mobile Data Options; 4. Press Voice & Data.; 5. Press the required network mode. ...
Cricket2
Chalupa_Batman
Hey @Cricket2
Here's a step by step.
How to change Network Operators on Android
Find network operators by sliding your finger downwards from the top of the screen.
Press the settings icon.
Press Connections
Press Mobile Networks
Press Network operators
Press Select Manually and wait till your phone searches available networks.
Press the either AT&T or T-Mobile
Press the Home key to return to the home screen.
Now reboot and you should be ready to go!
Created by Chalupa Batman
@Cricket2
text will work as long as you can connect to the proper PM's roaming partner
Critical part to US roaming depends on T-Mobile/AT&T coverage and whether you can connect successfully onto either network.
If the phone is not connecting to T-Mobile/AT&T, change the Network Connection from Automatic to Manual and select and test both T-Mobile and AT&T and see which one you can connect.
And, make sure your Roaming Mobile data is enabled and you have disabled your mobile data limiter.  Also change your network mode to 4G (and don't try 5G until you can connect and works on 4G)
Also, you can download VoIP app TextNow as a workaround to make calls and text if you have Wifi or if your roaming has data component and data  is working
