US add on not working
Jerry009
US roaminG data not working, US roaming calling and texting not working. All Us add ons not working.
10 REPLIES 10
@Jerry009  "Won't let me submit ticket. Gives error code"  Are you using the link @Handy1 gave you which is a private message to customer service?  If you're trying the chatbot/ticket system, it's broken and gives errors so use the link.
Jerry009
I have the text calling data one got it Dec 24 left Dec 25 still in US. Dosnt work
Jerry009
Jerry009
Tried 2g network didn't work
Phil_Adelphus
@Jerry009   ". All Us add ons not working."
You have more than one US add on?  Which ones do you  have and when did you buy them?
@Jerry009  Please submit ticket with support see if they can compensate you for the troubles
send  a  private message   To CS_Agents
HI @Jerry009
you tried T-Mobile and 2G?
where US you are in?  what phone you have?
you might need to try again using T-Mobile 2G in a different area
Jerry009
Tried this. Still dosnt work
HI @Jerry009
check if you connected to T-Mobile or AT&T.  Try both and see which one works.  Make sure you dont use 5G, change to 4G
you have data? make sure data raoming is enabled on your phone
SMS should be easier, check it first
if voice does not work, connect to T-Mobile only and change to 2G and test
@Jerry009  First make sure you have data roaming turned on in phone settings and set phone to 4G/LTE and connect to T mobile or AT&T also if you haven’t rebooted the phone do that aswell . If you still have issues with voice you can try set phone to 2G and connect to T mobile
