US add-on not working
Laffydaffy
I bought a U.S. add-on for $30 but it is not working properly; I can receive texts but I cannot send them, plus I cannot make calls to Canada…. so frustrating! TIA
8 REPLIES 8
Laffydaffy
Yes
Laffydaffy
Already did all that 😟
Laffydaffy
I believe I did because I have data, in fact I can tell how much of my add-on data has been used since arriving in Hawaii. It also says I have used zero amount of my available texting, like it’s taunting me!😟
Laffydaffy
Yes, connected to T-Mobile and data roaming is on. Thanks
mehaylatyler
This^^^ I had the same issue, you have to change which network your phone is connecting to, as long as it's AT&T or T-Mobile, you shouldnt have any issues. Make sure your Data Roaming is turned on!
hairbag1
@Laffydaffy
actually sounds to me like you didn't purchase the 15 Day US Roaming add-on successfully. Can you please log in to your account and look in Subscriptions and Add-ons...just to confirm you got the right add-on.
@Laffydaffy
You will need to connect to AT&T or T-Mobile network on your Network Selection for service in the USA. The connect might be better on one network than the other so try both network.
Also go to your Setting and enable Data Roaming.
Gwanzi
do you turn on roam function?
