US Services are not working
Katbedn077
I purchased the 15 days services talk/text/data. After one day it stopped working
7 REPLIES 7
Katbedn077
Purchased one day before trip. Still 11 days of the service left
@Katbedn077
If you have tried all that, and you still can’t get service, ask a customer support agent to consider what may be the issue.
Best case, they can help resolve it, worst case they can credit your account the amount of the purchase.
To contact a Customer Support Agent, send a private message to the Customer Support Agents by clicking here
You’ll need to be logged into your Community account for the link to work.
HALIMACS
@Katbedn077
when, precisely, did you make the add-on purchase?
The add-on expires 15 days after purchase, not 15 days after entering the US.
I say this only because some other folks have purchased it a week or more prior to their departure, thinking it only came into effect once they enter the US.
If it was less than 15 days ago, and you still cannot get it to function, can you try manually selecting AT&T and or T-Mobile?
And also make sure your roaming is turned on.
Katbedn077
is there any outage of these networks in New Jersey? Bayonne area.
@Katbedn077
Try manually connect to T-Mobile or AT&T network in your Cellular Network. Depending on the cell tower location near you. One might be better than the other one.
Katbedn077
It is roaming: 3GB data, talk, text ($30). It was working last night from the same location. Now the phone states "Emergency calls only"
Is this a raoming add-on?  If you haven't already tried, please try restarting your pyhone.  If you've travelled to a different location, it's possible that the signal is weak there.
