10-25-2022 02:51 PM
I have auto payment. Do I need to put money into my account before adding US Roaming services or will the amount just be added to my next billing and automatically charged?
10-25-2022 03:29 PM
This post might help explain things....
10-25-2022 02:54 PM
It's a cart method. You select the add-ons you want and then you pay for it with the registered card or vouchers.
Be aware that talk is very dodgy these days. You'll need to manually connect to T-Mobile to get the best chance. Even then might be problematic.
10-25-2022 02:54 PM
@Skookumchuk You buy US roaming whenever you need as the 10 days , 240 hours , expiry time will start after a successful purchase.
If you have a CC on the system, no need to load money ahead. It is now a shopping cart concept, you add the roaming addon you need, check out and PM will charge from your credit card on file
