06-11-2024
02:06 PM
06-11-2024
06:27 PM
computergeek541
I’ve paid for a US roaming package but I cannot phone home from Las Vegas.
06-12-2024 12:30 PM
Yeah, AT&T won’t let me talk, T-Mobile seems to work.
Thanks
06-12-2024 12:20 PM
iPhone 7. Worked last year same place same US package.
06-11-2024 02:24 PM
hi @Erskine99
just voice problem?
what phone you are using? are you connected to AT&T or T-Mobile? try connect and test with both.
06-11-2024 02:10 PM - edited 06-11-2024 02:12 PM
do you have a VoLTE enabled cellphone that on the PM whitelist of PM Volte enabled phones ?
Make sure to connect only to either AT&T OR T-Mobile.
clipped from Help Files...
To check if your device is VoLTE-Roaming enabled, please check this list:
06-11-2024 02:09 PM
@Erskine99 , what phone are you using? It is possible that your phone is not whitelisted for VoLTE service in which case the only way to complete a phone call is to connect to T-Mobile and hope that they still have 2G coverage in your area.
