03-18-2019 10:59 PM - edited 01-05-2022 03:48 AM
I'm in Tampa with a US Roaming plan (talk, text, 500MB) and all calls (to/from Vancouver) drop at 45 seconds. How to fix this?
Rob
03-20-2019 03:07 PM
I'm really glad to hear that, @ReillyWood! Ejoy the rest of your trip
03-20-2019 12:53 PM
FYI - that was the problem. Moderator fixed it and I was able to have a call longer than 45 seconds (although we only tested it for about 60 seconds).
Thanks all for your help and guidance.
Rob
03-19-2019 04:50 PM
I hope they get to you quickly, @ReillyWood--best of luck! 🙂
03-19-2019 03:22 PM
Thank you. Already done. But I think someone said they were busy so I guess it'll be a day or two. But at least the problem is known.
I'm not sure how I got two roaming packages. I recall there was a problem in getting the initial credit, but that seemed to work OK and I only did subsequently buy one roaming option (data notwithstanding).
Alas, it is what it is and not overly severe just annoying.
Thanks all for your help.
03-19-2019 02:49 PM
@ReillyWood wrote:
So, how to remove one?
@ReillyWood as I said, unfortunately you can't do this yourself, you need to contact the moderator team via private message and wait. More info on that here: How to Get Help
Please be careful when purchasing US Roaming add-ons so that you don't get yourself into this situation again.
03-19-2019 02:47 PM
My apologies - you're right. I was only looking before at the overview screen. Under Plans & Addons, I see two US Roaming - Unlimited Talk plans.
03-19-2019 02:39 PM
@Alex888 wrote:
@ReillyWoodMultiple US plans of any type can cause bugs, you will need to contact the moderators.
@Alex888 no, the data ones are fine to stack.
@ReillyWood sign into self-serve and click on Plans and Add-ons tab. In the lower half ("My add-ons"), do you see US Roaming Talk listed more than once? If so, this is the cause. The only resolution is to contect the moderator team via private message as noted in a few resoponses above, and ask them to please remove one of the US Roaming Talk add-ons for you. Unfortunately, they seem to be quite backlogged again so please try to be patient.
03-19-2019 11:32 AM - edited 03-19-2019 12:10 PM
FYI - I tried this but it didn't fix the problem. Possibly it shortened the timeout to about 20 seconds (only tried one call afterwards).
Edit: I meant I tried reporting my phone as missing, then removing this, and rebooting my phone.
03-18-2019 11:18 PM
@ReillyWood wrote:I've called my wife in Vancouver about 7 or 8 times and she's called me back 2 or 3 times, each time the connection ends at 45 seconds. In between, I did power-cycle the phone once and looked to see if there were any blatantly wrong SIM/network settings (didn't find any).
If none of these suggestions correct the problem, you'll have to do as previously suggested and contact a moderator...keep your calls to wife at 44 seconds in the meantime !! 😆
03-18-2019 11:12 PM
03-18-2019 11:11 PM
Try calling someone else in Canada and see if the problem continues.
03-18-2019 11:11 PM
@ReillyWood wrote:I have only one talk/text plan as far as I can tell, but I do have two data roaming plans (one for 250 MB and one for 500 MB - don't ask me why :/). Might that be the problem?
@ReillyWood The other posts I saw only mentioned multiple roaming talk add-ons. Perhaps someone with some more first hand knowledge about this situation is watching and might have something to offer. If you have tired other suggestions, you might want to message moderators. Perhaps they can find out what is going on. Might be a day or two delay in getting a responce due to the heavy load right now.
You can click here to send a private message to the moderator team.
03-18-2019 11:08 PM
03-18-2019 11:06 PM
03-18-2019 11:04 PM
03-18-2019 11:02 PM
@ReillyWood wrote:I'm in Tampa with a US Roaming plan (talk, text, 500MB) and all calls (to/from Vancouver) drop at 45 seconds. How to fix this?
Rob
Never hearda such a thing happeing. Does it happen on every call or just to that number ? Check on your phone settings. Cycle phone off/on. Let us know if it continues or what happened to correct issue. Thanks
03-18-2019 11:00 PM
Hey @ReillyWood - I read on another post that if you have multiple US roaming talk packages at the same time, this can happen. Any chance that is your situation?
