US Roaming does not work
oilpaint
purchased US Roaming 2 days ago and have yet to have it work. I didn't even check if it worked until I was semi-lost in a new city. What can I do? I messaged mods, my roaming is ON.
9 REPLIES 9
Good going !
Drive safe.
@oilpaint wrote:
hi! Yes it does show up in my self serve
What shows up?  Available funds or the actual roaming add on?
oilpaint
wow, when I manually selected AT&T instead of the automatic T Mobile it started working! thankss!!
So you've paid for the roaming...now go back and purchase the actual package you've paid for.
oilpaint
hairbag1
Log into My Account...do you see $$ in Available Funds ? If so, you've likely paid for the Roaming package but now you'll need to go back and actually select it.
Just to confirm...you did want the 10 Day US Roaming plan ..right ?
You may have to manually select ATT or T mobile to get things aworking.
Let us know how you make out.
Triguy
It is a two step process - you need to add it then purchase.
https://www.publicmobile.ca/en/bc/get-help/articles/us-roaming
RossN
@oilpaint In your data and add on section does it show up? some people put money in account but dont complete second step
bravo_md
Not much can be done now.  By the time you hear back from mods the ten days will be up.
