US Roaming - Florida
Bishop
Hi,
We are going on vacation this summer to Florida.  I am wondering if the US roaming add-on will work while we are in Florida.  We would like to be able to use talk and text.
Thanks in advance.
Luddite
@Bishop  In addition to all the other info, get a textnow SIM if you can https://www.textnow.com/wireless. It will provide free cellular calling and texting and their data plan may be cheaper than PM add-ons.
darlicious
@Bishop
If you are vacationing for 30 days or less then the 10 day US Roaming add ons will probably work best for you but the decommissioning of the 3G network in the US presents an issue for pm's voice services. Officially July 1st 2022 is the end date for T-Mobile with at&it's official end date has long since passed. While it is still possible in some areas to still get 3G network access there's no guarantee.
However there is a workaround. Before you leave download a voip app such as textnow. You can also change your voicemail message directing callers to phone your textnow phone number.Manually top up your self serve account balance with enough funds to cover your projected cost of needed roaming add ons. Make sure you know your 4 digit account pin #. This way if needed you can purchase US Roaming add ons  with your available funds or the credit card on file via the 611/IVR system or by calling 1 855 4PUBLIC and entering your 10 digit phone #.
In the day of departure or upon your arrival purchase just a 10 day US Roaming Data add on ($20/1gb/$15/500mb/$10/250mb). Make a note of the time of purchase as it will expire exactly 240 hours (10 days×24 hrs) later. If you wish to purchase the same add on you either have to wait 24 hours or contact customer support to add the same add on for you. You can purchase a different one immediately.
Once purchased ensure you enable roaming. Reboot your phone. Manually select either at&t or T-Mobile. Now you have access to the 4G LTE network. Regardless of any roaming add on you will recieve incoming pm SMS text messages. You can use textnow to send and recieve SMS texts and make and recieve voice calls. The textnow app will work on both wifi and mobile data and uses approximately 0.5mb/min for voice calls. MMS texts can be sent and recieved via mobile data. And if you need mobile data you have it.
HI @Bishop
There are different roaming add-ons you can purchase but they all come in 10 days expiry.  So, if you go longer, you will have to keep buying.
If you go there for a long trip, or if you need more data, you will be better off to buy local prepaid data instead
DDM69
MrSpock
@Bishop hi yes it works in Florida remember it is 10 days dont buy until you are going as it starts right away have a great trip!
