07-04-2022 03:48 PM
My plan is expired because I forgot to update with my current visa card, It was suppose to renew today.(july 4th 2022) I went into my account and replaced with new visa . My current plan is $50 which was suppose to renew today, but it's still saying my plan is expired. My daughters and husbands accounts have the same issue.
07-04-2022 04:29 PM
07-04-2022 04:17 PM
@hTideGnow wrote:Hi @mazieriver2 you added the new credit card successfully?
Autopay way NOT try again even you added new card. You have to go and pay manually. Please try to use the option "Other.." and do not try to use "Amount Due". "Amount Due" has problem often
To avoid confusion-
07-04-2022 04:14 PM - edited 07-04-2022 04:28 PM
Autopay way will not try again even you added new card. You have to go and pay manually. Please try to use the option "Other.." and do not try to use "Amount Due". "Amount Due" has problem often
07-04-2022 04:13 PM
ok I will try that
07-04-2022 04:12 PM
07-04-2022 03:58 PM
@mazieriver2 hi if you just replaced your card you may need to make a manual payment if your plan says supended look for a reactivate button and press it to resume service reboot phone
07-04-2022 03:52 PM
You now need to make a manual payment. Use the other amount option, not amount due.
