US Roaming Addons
Jrey1
I can't find any information online about US Addons. For example, if I'm roaming in the US for a week or so, what options do I have and how would i go about it?
Thanks
Phil_Adelphus
@Jrey1   Is your phone on PM's VoLTE list (scroll to the bottom of the link)?  If not you may have difficulty with voice calls unless you can connect to T-Mobile's 2G network.
https://www.publicmobile.ca/en/on/get-help/articles/volte
DennyCrane
https://www.publicmobile.ca/en/on/plans#ALL
Bottom of the page under add-on's
dabr
@Jrey1   Login to your self serve account (using clean browser or clear cache/cookies) and select Add-ons top right of the overview page and you will be able to purchase either talk/text roaming add-on or data roaming or bundle including talk/text/data to purchase which are for 15 day duration.
Keep in mind the add-on becomes active immediately after purchasing, so best to buy close to your travel date.
hi @Jrey1 PM  roaming addon are all 15 days long. PM uses T-Mobile or AT&T  networks.
They have Talk/text/3GB data for $30. Or you can get Talk/Text roaming only.  The 15 days counter starts after the sddona is purchased, so wait till you start your trip
