12-29-2016 10:33 AM - edited 01-04-2022 01:25 PM
Hi,
I just added US Roaming for 10 days, $20. My credit card was charged and I can see available funds $20. In the add-ons, I don't see the feature added to my account. I also didn't get any email or text message confirming that add-on is actually added to my account.
How to confirm the US roaming add-on is actually added to the account?
Thanks,
Cash
09-19-2019 06:22 AM
@cash wrote:Thank you Will13am.
I had to buy the add-on twice.
1st time it was charged on to credit-card
2nd time, it will be deducted from the balance.
Now I can see the add-on added to the account. This is confusing way of adding the add-on. Once the credit card is charged, the add-on should be added.
Thanks for your guidance.
You're not buying it twice...your adding money to your account then making your choice and paying for it. It's like a vending machine. You put your money in but the vending machine doesn't know what you want...you have to choose "coke" or "sprite" then you get you're soda of choice. Only difference in there's no coin return button and pm doesn't give change back. So like the bus..exact fare only. Or a reloadable card. Analogies over.
09-18-2019 11:22 PM
@TanisD_1 wrote:Hello, I have done the US roaming add on before with no problem. this time I made a "payment" of 20.00(I already set up on autopay) and it isnt showing in my available funds or account balance. suggestions?
Can you confirm that the charge went through to your card?
09-18-2019 11:20 PM
12-30-2016 04:14 PM
Hey all,
If anyone needs us to verify the add-on purchase, don't hesitate to send us a message. You also don't need to 'buy' it twice; it should work on the first try 🙂
Mary
12-30-2016 04:02 PM - edited 12-30-2016 04:09 PM
Thanks for asking this. I was just going to ask the same thing. I didn't realize you need to "buy" twice to get an add on.
I should add that on my second buy attempt the website is stuck at "This may take a minute or two" for 5 minutes now. ![]()
12-29-2016 09:38 PM
If U were charged 2x, send a PM Mod a private message, they should be able to rectify this
12-29-2016 05:32 PM
Yes, it is a 2 step process. They should have instructions for that to avoid confusion over this addon.
12-29-2016 11:44 AM
@cash yes it has been a known issue with that addon anyway that the money gets charged to fyour credit card but the funds go to available Funds rather than to the addon. So as you found out you needed to go back in and get the addon again. As you seem to be a newer member here a great way to show your appreciation for the help @will13am gave you, you can mark his post as a solution to your issue.
12-29-2016 11:17 AM
Thank you Will13am.
12-29-2016 11:06 AM - edited 12-29-2016 11:06 AM
I am not totally familiar with buying add-ons, I thought the steps were top up the account so there is money available to make the purchase, buy the add-on. If you are showing funds in the account, it would appear the money hadn't been used to make the purchase.
