07-24-2023 12:59 PM - edited 07-24-2023 01:03 PM
I have three questions regarding this plan, therefore I have included them all in this thread.
1. Is the 40GB • $50 Canada-US Plan just a temporary Promotion that's available to all of Canada long term, or is this a limited time Plan that may be taken away at any given time?2. 'Calls to 411, 511, Reedly, California (559-726-XXXX), Carroll, Iowa (712-775-XXXX), Lake Park, Iowa (712-432-XXXX), Charles City, lowa (641-552-XXXX), Pine Ridge, South Dakota (605-562-XXXX), Redfield,South Dakota (605-475-XXXX), and Fort Thompsons, South Dakota (605-477-XXXX) are not included.' (Why??)
3. Even when on the MB Website in the 40GB Plan it shows 'Offer Details' and has Finer Print regarding the selected Plan.. at the very very bottom, it says 'This plan is for Quebec residents only and intended for use in Quebec.', however it's available to all of Canada with this message not being removed or updated.It says this is only for New Activations Only, yet anyone can switch to this Plan within their My Account, or is that referring to just e-SIM only?
Plans
08-10-2023 07:27 AM
True, But, Can You imagine If 2/3 of PM Clients switching to the $50 Can-US Promo Plan?
Especially the 5G?
That would signify what PPL Love
07-26-2023 02:35 AM
I'd have to assume, if using a Calling Card, Only Way to call those #'s, If using Whatsapp, Perhaps only way to call those #'s
07-24-2023 03:05 PM
See those little symbols in front? Like **Whether... ? ***Limited...? +This...?
Those link back to elsewhere in the plans displays. The last one links back to only the QC region and the QC-only plan. If you go there then you would see that + symbol.
Apparently they're called Chicago-style footnotes. Though this style uses endnotes, not footnotes.
07-24-2023 01:13 PM
and for your second question,
Telus has the same rule, so, we are just following
Why? could be due to Traffic Pumping with "some local exchange telephone carriers in rural areas of the United States inflate the volume of incoming calls to their networks, and profit from the greatly increased intercarrier compensation fees"
Check this posts when it was first announced on PM, there were some discussion about it
07-24-2023 01:04 PM
1. The offer is definitely limited time offer for now, I guess it depends when will Freedom pulls that plan away, but once you are in, you are in. PM always honour grandfathered plans
3. the offer details was just a templates that PM uses for all Provinces. So no worry
07-24-2023 01:01 PM
It also says 'Calls made to numbers starting with the following six digit combinations are not included in US calling from Canada and will not be completed when dialed: 712-432, 605-562, 641-552, 605-475, 605-477, 712-775, 559-726. Calls made to numbers starting with the following UK codes are not included in UK calling from Canada and will not be completed when dialed: 4470, 44870-44879, 44843-44845.', within the 'Details' Section.
