3 weeks ago
I have the US/Canada plan but have no service in the Us. I have tried connecting manually as well as automatically but nothing.
My husband gets service and our phones have the same settings but I don’t have any service.
3 weeks ago
Can you log into your account and double check your plan features? There were 2 5G plans offered awhile ago with the same price and apparent features but one was a Roaming plan and the other offered unlimited slow data after the plan data was used.
3 weeks ago
@Pinny first try rebooting the phone if you haven’t already ? Do you both have the same phone , might be issue with voLTE , but get your phone set to 4G/LTE not 5G and connect to T mobile AT&T or Verizon and ensure you have data roaming turned on in phone settings , but check if your phone is in the voLTE whitelist if it’s not you most likely won’t be able to use for calling
VoLTE white list
3 weeks ago - last edited 3 weeks ago
Did you try to exchange SIM cards to eliminate phone (hardware) issue?
If you have identical phones check all options HE has and adjust your phone accordingly.
Do you have the same plans, too?
