US Canada plan
Costas12
US and  canada plan. Why is  my phone not working in the US.
hi @Terryscell the Canada-US plan allows you to call from Canada to US as well (also call from US to US and  Canada)
Terryscell
Just to check; do you have a plan which allows calls *from Canada* to Canada and the US, or *from Canada and the US*? There has been some confusion on plan titles.
Sansan
What type of phone do you have?
It must be on Public Mobile's whitelist .
https://www.publicmobile.ca/en/bc/get-help/articles/volte
KZ1964
Make sure your phone is on roaming.  If you have your phone set for automatic selection ie AT and T etc then set it to manual and try selecting networks manually
eddieO
@Costas12 check to see if you have Data Roaming turned on. Next, check that you are connecting to either T-Mobile, AT&T or Verizon. Let us know if this helps.
