UK add on , can't use it
kinghun
Tried calling UK using the 1000 min UK  add on . At first it didn't acknowledge that I had the add on . Trying to phone a mobile number
@Phil_Adelphus
the main idea I offered for OP is to drop that 0
and technically, mobile phone has an area code.
if the mobile number is 0 7890 123 456, the area code is 7890. However, most people would not consider this to be an area code because it does not point to a particular patch of land to which mobile phone “belongs”. It’s basically just part of the number.
But honest , that part of "area code" is more a "mobile carrier code".  It use identifies which carrier owned that number originally or numbers assigned before 2017
@softech   For calling a mobile UK number you don't use the area code, there should be ten numbers after the 44, so it should be 011 +44 **** ******   You use the area code if calling a landline but the OP is calling a mobile so it's different ("mobile code" instead).    The + may be optional, but it shows for a UK cell number in my contacts (which I haven't called in a long time as we usually use iMessage these days).
@kinghun
To call UK, drop the 0 before the area code
For example,
      calling London number 020 8765 4321 should be just call 01144 20 8765 4321 (you can also try +44 20 8765 4321)
       Calling Manchester number 0161 765 4321 should be just 01144 161 765 4321 (you can also try +44 161 7654321
**Calls made to numbers starting with the following UK codes are not included in UK calling from Canada and will not be completed when dialled: 4470, 44870-44879, 44843-44845.
Phil_Adelphus
@kinghun   Try this, note it is different for calling a UK cell phone as opposed to a landline
https://www.wikihow.com/Call-London-from-Canada
fixin1
@kinghun - Are you calling any of these numbers?
If not, please make sure +44 in front.
If not, please contact CS_Agent here:
⬇️ Click the link for an Agent * ⬇️
If the link above doesn’t work correctly, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. * CS_Agents are at load due to iMessage activation issues so it may take longer than 48 hours. * They work 7 days a week from 9 AM to 10 PM EST.  You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
