account says unauthorize.
Cody92
cant sign into account it says unauthorize everytime i go to sign in.  this has happen multiple times now im gonna leave public mobile if i dont get help and have this fixed once and for all.
@Cody92
I had different issues in the past that an agent can’t figure out. So ask them to have the Technical section look into this. It may take a few days for them to figure out.
Dunkman
@Cody92
The website is finicky.  Try a different web browser, clear cache or incognito mode.  Or try on a different device.
You could also try to login on the PM app itself.
@Cody92 wrote:
I can't sign into my account evrytime that i try it just tell's me unauthorized, contact customer support and i dont know why its doing this.
Understood. Use the link I gave you and you can dm Customer Support. They're likely gone now but should get back to you early tomorrow.
Cody92
it just says this For security reasons, we couldn't log you in at this time. If you believe this is an error, please contact Customer Support for assistance.
Cody92
hairbag1
@Cody92
ok...use this link to message Customer Support. Let them know the problems you're experiencing...
