01-05-2022 10:11 PM
I purchased a roaming package and when I used the data, I purchased more data. At this point only calls work but the data is not. I have configured all the APN settings referenced by the support bot and help articles and still nothing.
Any idea what to do? My phone is a OnePlus 6T
01-06-2022 01:31 PM
@naromerol can you please go to Settings, Wi-Fi & Network, tap on SIM 1 or SIM 2 (whichever one has your Public Mobile SIM card), and look under the NETWORK SETTINGS heading. Do you have "Roaming" turned off? This switch controls whether or not you connect to data services while roaming. If you have that turned off then even though your calling works, you would not get any data in the US.
01-05-2022 11:22 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
or visit Here link,
APN Settings On Android device
click Here link,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
make sure enable roaming on,
Try manually selecting either of AT&T or T-Mobile, whichever works best for you,
for Re-Purchase Add-ons you need to wait 25 hours after the expiry first Purchase Add-ons or you need to Contact Customer Support Agent by CS_Agent, to do it for you..
Good Luck.....
01-05-2022 11:10 PM
@naromerol wrote:I purchased a roaming package and when I used the data, I purchased more data. At this point only calls work but the data is not. I have configured all the APN settings referenced by the support bot and help articles and still nothing.
I know that you were only checking and making adjustments to your APN settings just in case they got changed somehow by mistake, but as your data was already working, your APN settings would have already been correct. Also, I'm aware that there is some confusion with some people saying that you need to use different APN setttings while roaming; this is not the case as the APN settings are the same setttings for Public Mobile whether you're using the data in Canada or while roaming in the U.S.
01-05-2022 10:31 PM
Does the 2nd addon show up under your My Plan Details area? And, is it a different one than the one you are currently using?
Or, are the funds still showing in your Available Funds area? If so, try to go back and add the addon to your account.
If still issues, contact Customer support for assistance:
Open a ticket via:
https://widget.telus.tiia.ai/publicmobile/publicmobile.html (faster response time)
or send a private message to:
01-05-2022 10:22 PM
HI @naromerol , so you purchased 2 Roaming add-ons so far? The first one not expired yet? Was the first one the Talk/Text/Data combo ? which 2nd add-on did you purchase? I think if they both have Talk component, some weird thing will happen.
Also, you tried reboot your phone? the new add-on might not kick in without a reboot
01-05-2022 10:19 PM - edited 01-05-2022 10:20 PM
You cannot purchase the same roaming add-on while the current one is still within the 10 day usage period.
You would need to purchase a different roaming add-on or wait till the first one has expired (+24 hours) before adding the same one again.
