03-15-2024 09:45 AM - edited 03-15-2024 09:46 AM
In England for 2 days. WiFi works, but roaming options would be great. I only see U.S. options though.
03-15-2024 11:15 AM - edited 03-15-2024 11:16 AM
If you are only in the UK for 2 days, you can use WhatsApp if all parties have this app for free calling and texting through wifi.
03-15-2024 09:48 AM
@isoprax - Public Mobile currently does not have roaming outside the US. You will need to buy a local sim from a corner store or an eSIM (Like Airalo) for England (If your phone supports it)
If you are still in Canada / the US you can call forward to a TextNow number. If you are not, use TextNow app or Fongo to make calls there.
03-15-2024 09:47 AM
@isoprax Sorry PM only has roaming in the US . You best to get local pre paid SIM card in England for your time away
03-15-2024 09:46 AM
sorry, no UK roaming option. PM only offers roaming for US. For UK, you will have to use local data sim or travel esim for data, and add a VoIP app like TextNow for free voice calls to Canada
