05-10-2023 09:45 PM - last edited on 05-10-2023 11:53 PM by computergeek541
05-11-2023 01:54 AM
05-11-2023 01:43 AM
Hopefully the person with the number didn’t reply to the text to port over the number to PM.
05-10-2023 10:06 PM - edited 05-10-2023 10:07 PM
Here or elsewhere, @Greid84 ?
If elsewhere, you'll have to deal with them.
If here, it's unlikely the owner of the number you entered will authorize the port, in which case after 90 minutes you can re-trigger it using the self-serve change number feature to port in.
05-10-2023 09:48 PM
@Greid84 you meant your typed in the wrong phone number?? There is a number to call to talk to live support, You can provide them the correct information and they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
