Almost zero data service
stevo909
Nearly zero data service. Can't load a simple website. Terrible, terrible service. Located primarily in Danforth area, tested throughout GTA with same results. Ready to leave Public on this.
So the service isn't terrible...
stevo909
I think that worked! will continue to test. Thanks much!
DDM69
Thanks for your review. Do you have a question?
gelmer
How many blips do you have? Are you on a 3 or 4G plan? I'm on west side and have never had an issue.
HALIMACS
@stevo909
Make certain your device is not trying to connect to local free Wi-Fi;  it may be utilizing that connection for your browsing as opposed to the data connection.
To ensure this, try to toggle Wi-Fi off when relying on data.
@stevo909 you just joined and have the issue?
what brand and model your phone?
try to first click Reset All Networks and see if it helps
If you have any VPN setup, delete them
if, you have the new iPhone, make sure you change the network mode to 4G and make sure it is not set as 5G
yuu might want to change to 3G just to test
