12-11-2025
10:21 PM
12-11-2025
10:52 PM
Hello, Would you be able to send me the porting support team number? Thanks.
12-11-2025 10:48 PM
Thank you
12-11-2025 10:42 PM - edited 12-11-2025 10:43 PM
There is a number to call to talk to live support, they can confirm the porting status re-trigger the process for you if required. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
But if you are unable to reach someone from the live support with the phone number I sent you, you can also message them here:
**After opening the ticket, please monitor your community inbox (envelope icon on the top right), the customer support agent will get back to you in sending a message there.
