12-12-2025
04:10 PM
12-12-2025
11:35 PM
computergeek541
I triple checked when I typed in the emei number during transfer, but after the port out you said it was wrong.
Waiting for a callback, 90 minute window is expiring.
604-xxx-xxxx
Edit: personal information redacted by will13am.
12-12-2025 11:33 PM
@slusagm wrote:
@marktigges are you porting into PM or out?And regardless port in or out. Always use account number and not IMEI. IMEI always give error
In case you are porting in, I have sent you PM porting support number for you to call and sort it out
Using IMEI doesn't always fail. The vast majority of the time, it works fine. There are also some cases of porting from certain brands that the customer is supposed to use IMEI. While it's true that account number should be used most times, it shouldn't always be used.
12-12-2025 04:14 PM
