07-01-2021 12:03 PM - edited 01-06-2022 02:40 AM
Need some help, Dad doesn't have data on his rogers plan and hasn't received SMS text to port his nbr. Will this mean he can't port it to PM? Any help with this is greatly appreciated.
07-01-2021 01:53 PM - edited 07-01-2021 01:54 PM
@deloreh : The phone (if compatible) should be able to do outbound calls and texts and data. Keep using the phone with the Rogers SIM until it stops working. If you answered yes to the text that is.
07-01-2021 01:50 PM
Thank you all. There was a problem activating the SIM once that was resolved by the agent I called everything is fine now. Just waiting for his PM account to activate.
07-01-2021 01:11 PM - edited 07-01-2021 01:12 PM
you don't need any data to received SMS, the normal Text message you will received
Make sure that you have the old sim card in your phone when you're porting your phone. You should get a message from your old carrier asking to confirm if you would like to port your number. Your reply should be: YES.
The confirmation message can take a few minutes to come in. You have 90 minutes from the time of request.
Good luck and your Dad welcome to Public Mobile
with a Beautiful Service
you will be very happy
07-01-2021 01:05 PM - edited 07-01-2021 01:06 PM
@deloreh wrote:Need some help, Dad doesn't have data on his rogers plan and hasn't received SMS text to port his nbr. Will this mean he can't port it to PM? Any help with this is greatly appreciated.
Hello @deloreh ,
Submit a ticket using this link to help transfer over the number, to be put in touch with a Moderator.
07-01-2021 12:57 PM - edited 07-01-2021 12:58 PM
Your dad should get the SMS text from Rogers within a 90 minute window but it may take up to 2 hours with the Rogers SIM in his phone.
He just have to wait for the text and click YES that he is porting over to PM.
07-01-2021 12:46 PM
@deloreh : Whatever services were being subscribed to at the other end doesn't matter to what services will be subscribed to here. If a text can't be received like with a landline then other porting arrangements will be needed.
Got a make/model/submodel?
07-01-2021 12:37 PM
07-01-2021 12:34 PM
Thank you for your help. SIM for rogers is still in phone. He called and added data effective immediately. But they haven't tried yet.
07-01-2021 12:23 PM
@deloreh Was your dad able to receive SMS on his Rogers phone before?
Make sure he has his Roger SIM in this phone, power up
I will private message you a phone number to call, they can assist to re-trigger the porting SMS
07-01-2021 12:06 PM
@deloreh : If it's Rogers cell service then did he leave the old SIM in the phone? Also, what are the first 6 digits of the number if you mind sharing. Also, what make/model/submodel is the phone? If he had been with Rogers for quite some time then maybe he has an old phone that might not be compatible here.
