Trying to reset my password
LoriMac
no email is arriving to give me code
2 REPLIES 2
will13am
@LoriMac , by chance are you using an email alias with + sign?  This format will not work with the 2FA system even though it is legit as a username.  Check also the spam folder for 2FA emails.
RossN
@LoriMac
if password reset won't work you
 need to contact a customer service agent
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
