12-10-2022 11:20 AM
12-10-2022 11:46 AM
sometimes got error, then wait couple hours ok. you may complete the changes later.
12-10-2022 11:27 AM
When using self service clear your browser cache and go incognito. If you do not know your password try the Forgot your password link.
12-10-2022 11:27 AM
@maisiesansome12 you have problem logging in?
did you try to use the Reset Password link? enter your email address and wait for the reset password email to arrive
if that does not work, please open ticket with PM support and they can sort it out for you
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
