05-28-2019 01:05 PM - edited 01-05-2022 05:07 AM
06-25-2020 05:46 PM
@duffer900 wrote:The Public Mobile voice mail number is local area code+5804001. For example, the GTA voicemail number is 16475804001
Not always, but often. For example, there's no voicemail numbers in "old" area codes like 416, 604, 403, 250, etc.
Here is an updated list I came up with:
06-25-2020 08:56 AM
Did you try calling your voicemail from another phone, such as a land-line or someone's else's phone? Can you access your voicemail that way while your issue gets fixed?
06-24-2020 04:03 PM
I had this same thing happen and they told me it was because I already used up all the minutes in my plan.
05-28-2019 01:48 PM
@patrickyee , if you ignore the warnings and let the call continue, does it go through successfully? If it doesn't, it would be an account provisioning problem. In that case you need to get the moderator team to reset the account. The moderator team can be reached via private message using this link. Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
05-28-2019
01:39 PM
06-24-2020
06:45 PM
computergeek541
@patrickyee wrote:I'm trying to check my voicemail today and I can't, an automated voicemail says I need a long distance add-on to check my voicemail. Whats wrong with Public Mobile, I cant even make local calls without getting the same recording?
Strange, maybe confirm that the VM number didn't get messed up somehow.
If holding down #1 doesn't work... As @sunflowershine said.
05-28-2019 01:34 PM
@patrickyee It should not be like this. As long as you hold on the "1" key, it will take you to the voicemail selection.
