08-17-2018 03:55 PM - edited 01-05-2022 05:25 AM
Hi @CS_Agent
I recently travel to Asian a lot, and I found the PM doesn't have the international services. The only thing I can do is forward my PM call to Fongo. I believe this situation is very common. I wonder if PM have an idea or plan to carry out true international roaming services. Hope our moderator can answer my concern.Thank you.
08-18-2018 10:21 PM
If you are travelling lots of APPs to use with WIFI no need roaming now a days, unless you are on business trips, then you don't need PM
08-17-2018 05:39 PM
I know koodo just raised their usa and international per day fees. I think USA is 8$ / day, int o can't remember . I always get a local sim. If that doesn't work then the only options is finding a workaround like fongo or going to a different provider.
08-17-2018 05:09 PM
Why not shop local which is always less expensive.
08-17-2018 04:27 PM
PM tends to be a "no frills" type of carrier. I think many would consider international roaming to be a "frill", so I would not count on it becoming available anytime soon.
Telus wants to push people interested in things like international roaming to move to Koodo or Telus.
08-17-2018 04:12 PM
@nishufan wrote:Hi @CS_Agent
Moderators do not know. Brooke knows but doesn't tell us unril implemented. Proceed on the assumption the answer is "no". It took 3 years of requesting to get USA roaming.
