09-23-2023 11:49 AM - edited 09-23-2023 11:57 AM
I recently switched from Freedom Mobile to Public Mobile, but I found the VoLTE function is no longer working. When I make phone calls, it drops to 3G network.
I’m using Poco M3 Pro 5G, and here are the screenshots. Also, I use sp.mb.com APN.
I’d also like to know if anyone without a phone from Public Mobile’s approved VoLTE phone list has been able to use VoLTE.
09-27-2023 12:47 PM
I came across some posts that seemed to confirm what you were saying.
American model Samsung and VoLTE : telus (reddit.com)
This post on Reddit discussed Samsung phones bought in the US and their compatibility with VoLTE on the Telus network. Apparently, Telus had previously removed some devices from their approved list for enabling VoLTE but later added them back. It's possible that Public Mobile had a similar experience.
Another post shared a story about someone who escalated their VoLTE issue on a bring-your-own-device plan to the CCTC, and the problem was eventually resolved.
09-23-2023 02:22 PM
hi @polarfog
many carriers also have its list of VoLTE compatibility list even Telus and Koodo, but PM list seems to be a shorter one
And yes? whatever plan you have, you can frerl connect to 3g or 4g or 5g networks
09-23-2023 02:12 PM
@will13am, if you previously could use VoLTE on Public Mobile for your phone, but now you can’t, it’s even worse than never having VoLTE.
Moreover, this is my first time learning that Public Mobile has an approved device list for 5G connection. Although I purchased a 4G speed plan, my data connection runs on a 5G network.
09-23-2023 12:42 PM
@polarfog , you have been subjected to vagaries of the VoLTE whitelist which appears to be quite restrictive. I have a phone that started off on the whitelist and got booted for unknown reasons. Be happy you have 5G which appears to have its own whitelist.
09-23-2023 11:54 AM
Unfortunately, your phone is not on the approved Public mobile list for VoLTE services.
See the article below:
https://www.publicmobile.ca/en/on/get-help/articles/volte
Public mobile may add other phones to the list in the future, but unsure about timing.
