05-18-2024 11:47 AM - last edited on 05-18-2024 11:50 AM by softech
Hello, I am trying to connect my new number ###-###-#### and neither can access my account **@** please I need help ASAP
05-18-2024 11:52 AM - edited 05-18-2024 11:56 AM
I understand you said you cannot access your account. But was it just the 2FA problem? If so, you can use email to receive the 2FA code
On the screen it is expecting you to enter the code, click Didn't get the code? or Resend code and then choose Send email
If you really cannot login even with Send email option, please message support agent
If you can login with the help of email to receive 2FA code, go to My Account to request Change Sim card (please note that due to some glitches, accessing change sim care from mobile phone or tablet might not work for some accounts, you might want to use make a change sim card request on a desktop or laptop computer )
(If you are unable to login as you don't have a phone to receive the 2FA code: On the screen it is expecting you to enter the code, click Didn't get the code? or Resend code and then choose Send email)
After you logged in, unsuspend first if you have suspended your service earlier
Then go to Profile page, click on the Pencil besides the sim card number, follow the steps to enter the new sim card number and complete the change sim card request
(or direct link: https://myaccount.publicmobile.ca/en/account/profile/change-sim-number )
After the sim card is updated, wait 5 mins, then reboot your phone and it should be good
05-18-2024 11:48 AM
HI @Oreyes
first, we are just customers and this is a public forum, remove your email and phone number to protect yourself
is that new activation or just switch sim card on existing accounts? you can login My Account and do it yourself. Go to Profile Page , click the pencil besides sim card and update it
if you cannot login My account, then ask support agent to help. Message them here:
