Trouble transferring new eSIM. Solutions driving me in circles.
JasmineS
bought a new iPhone 17, tried to transfer eSIM from my old iPhone 14 to 17, and it said unsuccessful.  I tried to login into mobile app with new phone to purchase eSIM and it said unable to, please contact support.  Looking for help to get a QR code to activate my eSIM.
CSA_PM
Customer Support Agent
Thank you for the escalation! The customer is in contact with an agent.
JasmineS
Thanks I’ve been trying to contact support for the last two hours with no success
@JasmineS
your existing eSIM on the iPhone 14 still functioning?
on iPhone 17, uninstall the PM app, reboot phone and reinstall.  Login PM app, go back to Account page and try purchase eSIM once more and it should work
just in case it still does not work, ask PM support to check
 please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗
umnikke8
I don't think Public supports transferring eSIMs by any method. The standard approach is to use the app to purchase a new one on the new device. But since that is not working, I'd do as it says and contact support.
