05-12-2024
03:45 PM
05-12-2024
10:12 PM
Dunkman
While attempting to transfer our numbers to Public from Cityfone both my son and I received a text advising that we entered an incorrect ESN/MEID. Has anyone encountered this recently.
Thanks
Joining Public
Service
05-12-2024 10:37 PM
Thanks...it was an eSIM. Turns out that I should have used my Cityfone account number rather than my ESN/MEID. A CS_Agent did call and made the change for me as described by fixin 1 below. All is well now. Cheers!
05-12-2024 09:40 PM
Did you activate physical SIM card? If you did, what happens when you put the SIM card in your phone. Are you able to get any service? Able to text or call out? or incoming texts or calls?
Might be a stuck port.
05-12-2024 06:44 PM
Thanks!
05-12-2024 04:43 PM
@Dude91 - Try this:
And if you need help please contact CS_Agent or Cityfone customer service, you can reach Public Mobile Customer service here:
Submit a ticket via Chatbot:
⚠️ Public Mobile is Experiencing longer support wait times currently! Do Not Reply back to CS_Agent after submitting your ticket unless you solved it! Click here to bring up the Article! ⚠️
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
