10-03-2025
12:29 PM
10-04-2025
12:58 AM
computergeek541
Hi, I have several add-ons gathered over the years (additional data, international minutes, etc) and promotions, but unable to find them within the updated view. Ideally, they used to be visible within the rewards window, but can't find them now.
There have been so many changes in recent times that it's difficult to track everything at a time, and it's a consistently deteriorating experience.
Please help me locate my unused add-ons and promotions.
Thanks,
Prad
10-03-2025 12:55 PM
Thanks. It helped.
10-03-2025 12:34 PM
you can just need to expand the usage to see it. Login My Account of the app, click Usage Breakdown in the usage section
10-03-2025 12:32 PM
Your More is Merrier rewards will be listed under Subscription then under Usage Breakdown.
If it is not listed then you might have used it up.
10-03-2025 12:32 PM
At Overview click at
and you will see your subscription and add-on usage.
10-03-2025 12:30 PM
hi @Prad_222
they are there. After you login, click the "Usage Breakdown" under the usage odometer on the Overview page and they are there
