What happens if my phone is stolen???????
William122
The only way to get into this account profile is if I confirm the text sent to my (stolen) phone!!!! ???
1 REPLY 1
TheSterlinger
There is also the option to send code to your voicemail or email.
Click didn't receive code? And you'll see the options.
If these don't work for you,  then use the link below to send a direct message to get an agent to block for you until your are able to update information yourself.
