12-30-2019 09:33 PM - edited 01-05-2022 08:47 AM
Hello, can anyone help with information regarding travelling to the US. Is that what the US roaming package is so I can use my phone in the states? Thanks Nicole
12-31-2019 01:16 AM
@nicole7 For shorter trips the roaming add ons are convenient for longer trips not so much. Depending on how much you will need your phone and for what purpose you may want to consider other options. There cheaper roaming options by getting a US sim card if you have a dual sim phone this can be very convenient as you can still recieve incoming texts/calls currently on your pm phone. Getting an app like text now will allow you to call or text while on WiFi or with a data only add on or US sim card. There are also WiFi cubes you can rent and share with travel companions...google WiFi cubes for options in your ares.
If you do choose a pm US roaming add on...before your trip add some extra funds to your account and review the options available. On the day of your departure or when you arrive log into your account and choose and pay for you add on. It will start immediately...if you arrive later in the day and you can wait til after midnight et. to purchase this will allow you to get a full first day of roaming..
12-30-2019 10:25 PM
@nicole7 wrote:Hello, can anyone help with information regarding travelling to the US. Is that what the US roaming package is so I can use my phone in the states? Thanks Nicole
If you have the old $60 plan with US roaming minutes/text/200MB data, you are set for US roaming.
If you don't have the $60 roaming plan, you need to pruchase 10 days US roaming add-on.
12-30-2019 09:49 PM
Here are your US Roaming opitons:
12-30-2019 09:49 PM
@nicole7 Yes, you will need to purchase one of the US roaming addons. They are good for 10 days and the counter starts as soon as you purchase it.
US Roaming
