2 hours ago
Hi, i am travelling to USA, i have a Canada US data plan, do i still have to get adds on please? Thanks
2 hours ago
Wow, thanks so much for the quick response.
2 hours ago
no other addon needed
you just need to turn on Mobile data roaming on your phone. connect to T-Mobile or AT&T (you might need to manually connect and try both and stick with the one with better reception) , and turn off 5G, better ot stay with 4G
2 hours ago
No Add-on US Roaming is required. It is all included in the plan…talking, texting and data in both countries but enable roaming and VoLTE on your phone settings.
